Current division for inductors
Ramiel
Joined Feb 19, 2018
74
My eyesight isn't good enough to read that image. Try taking it again without the shadow across it and rotate it so that it can be read directly -- it's good practice to always try to make things easy for the people trying to give you free help.
Remember that when solving a differential equation the initial conditions either have to be given or there has to be additional information that can be used to determine them.
Take it step by step.
You have an inductor L1 that has a voltage, v(t), across it for all t >= 0 and has an initial current of i1(o) at t=0.
What is the current in this inductor, i1(t), at t > 0?
Give your answer in terms of v(t) and i1(0).
No inducter l1 does not have a voltage v(t), they are not parallel or am i wrong.
And here is the picture again. Ia m trying to first find the current entering both nodes
Moderators note : cropped and enhanced image shown in full size
Ramiel
Joined Feb 19, 2018
74
If the questiosn is as you said v(t) is parallel eith inductor 1, then it would be very easy but it is not
WBahn
Joined Mar 31, 2012
33,199
Focus here.
I pull an inductor, L1, off a shelf.
I put it into a circuit and let it run for a while.
At some point I start a clock and call that time t = 0.
I measure the current in L1 at t = 0 and call that I1(0).
I record the voltage across L1 for all time t >= 0 and call that v(t).
I give you the value of L1, the value of I1(0), and what v(t) is for all t starting at t = 0.
Can you determine what i1(t) is for all t >= 0 in terms of the information I give you?
Ramiel
Joined Feb 19, 2018
74
Focus here.
If i am given the voltage across l1, in your case v(t), i1(0), and the value of l1 then yes i would be able to do it. But it isnt the case here. Isnt it?
WBahn
Joined Mar 31, 2012
33,199
You keep asking about when you can and can't use that current division rule on two inductors in parallel. I explained why and you didn't follow it, so I am trying to walk you through, step by step, how to make that determination.
If you aren't interested in learning this anymore, just say so and I'll stop trying.
Ramiel
Joined Feb 19, 2018
74
No I am with you I am not asking about any rule. I want to learn. i said yes i will be able to find i1(t) then, what i am saying is that in this case the voltage across inductor 1 is not v(t) as shown in the picture.
I really want to know how i can go through this question
MrAl
Joined Jun 17, 2014
13,797
You are assuming that those equations are valid. They are NOT valid for the problem the TS is working with.
Well maybe you would have to elaborate a little.
Did you try using that information to calculate the required expressions?
Ramiel
Joined Feb 19, 2018
74
I
if i an able to find either i(0) or i2(0), i would be able to find the other using i= i1+ i2
But i am not able to find either
WBahn
Joined Mar 31, 2012
33,199
Just look at the solutions and you will see that your assumption that those equations work is wrong!
But let's assume they aren't.
You are claiming
i1=i*L1/(L1+L2)
and:
i2=i*L2/(L1+L2)
A direct consequence of this is that, at all time,
i2(t) = i1(t)·(L2/L1)
Since L1 = 6 H and L2 = 3 H, that means that
i2(t) = 2·i1(t)
What is i1(0)?
It is given that i1(t) = 0.6 A e^(t/0.5 s)
That means that i1(t=0) = 0.6 A.
Thus, you're claiming that i2(t=0) = 1.2 A
But we are also given that i(t=0) = 1.4 A.
Since
i(t) = i1(t) + i2(t)
i2(t = 0) = 1.4 A - 0.6 A = 0.8 A
Therefore, contrary to what you are assuming, those equations do not hold for this problem.
The reason why not is very simple and I have stated it repeatedly. I see no utility in stating it yet again -- go back and DO THE MATH!
Ramiel
Joined Feb 19, 2018
74
You are claiming
i1=i*L1/(L1+L2)
and:
i2=i*L2/(L1+L2)
i2(t) = 2·i1(t)
What is i1(0)?
Since
Can you check my attempt in post 28. I did the math but i cant find i2(0).
Any help?
Ramiel
Joined Feb 19, 2018
74
WBahn
Joined Mar 31, 2012
33,199
I only looked at the first one. I can make out the circuit with just a bit of effort, but I can't make out the first two lines of the work.
Ramiel
Joined Feb 19, 2018
74
The firs
the first picture is only meants for the circuit
Look at the other pictures for the work
bertus
Joined Apr 5, 2008
23,006
Hello Ramiel,
The pictures have to less information to get them enhanced, as I did before.
Do you have a flatbed scanner?
My printer here at home has one.
Bertus
Ramiel
Joined Feb 19, 2018
74
Hello Ramiel,
Bertus
Unfortunately i dont. You are not able to view the pictures clearly
