Cuircut board problem
kevinkhan
Joined Dec 3, 2010
12
I have a circuit board and the fuse keeps blowing. also sometimes the thermistor next to the fuse blows as well. What could be the problem and how will i trouble shoot the circuit board. Please see a photo of the circuit board attached. would really appreciate some help.
Dr.killjoy
Joined Apr 28, 2013
1,196
Have you tried to search Google for the schematic and work from there ... Also for help we need some basic info like wha
t is it for and model numbers and such ...
18,122
I don't think that's a thermistor. It might be a MOV surge protector.
Are you sure you're supplying the right power to this thing? Seems like you're trying to blow it up.
absf
Joined Dec 29, 2010
1,968
Was the fuse still blowing if the load (LED lights) is not connected?
Allen
Dodgydave
Joined Jun 22, 2012
11,395
Looks like there are 3 separate psus on one pcb, so they can be isolated from the input supply, then if you connect one by one and see when the fuse blows to eliminate it.
westom
Joined Nov 25, 2009
52
That acutally was useful, often you can pinpoint the bad component by smell.
Most damaged components have neither visual indication nor smell.
He describes a typical inrush current limiter. Damaged because some other failed part is probably causing excessive current flow. A part causing excessive current and the resulting damage probably has no smell nor visual indication.
18,122
-1
Visual inspection is a key tool, and smell can occasionally supplement what your eyes are telling you. A big dark circle that smells like phenol is like a red flag. You won't find everything this way, but you'd be rash to ignore the easy signs.
