Cue light circuit for Theater/TV
Stringle55
Joined Sep 7, 2017
10
I have started designing a basic cue light system for theater or TV use.
Basically what I want it to do is have 1 master station and 4 outstations. When a red button is pressed on the master station, the outstation lights up with the same colour. Then when I press the green button, the red light turns off, and a green one turns on. So far I have a working prototype with 2 buttons and 2 LED's, but when the green button is pressed I have no way of turning off the red LED.
The main issue is finding a way to stop the red LED from receiving power when the green button is pressed.
Both buttons are latching, and have their own 12v LED that is switched with them, both LED's are 12v also and connected in series via an audio/DMX cable(3pin) with pin 1 as green+, 2 as red+ and 3 as neutral.
Any help would be greatly appreciated!
Thank you
12,193
If the buttons are latching, that is the problem - the green button can't force the red button to release. One way to fix this is to use two buttons that are mechanically linked together (called a bail), so when you press one it releases the other.
To do this electrically, you could use a simple SPDT toggle or rocker switch with a center-off position. One side powers red, the other side powers green.
To do this electronically, change both buttons to momentary pushbuttons that toggle a flipflop that drives the LEDs. The flipflop can be relays, transistors, logic gates, or a flipflop IC; whatever your are comfortable with.
Is it important to keep the buttons you have now?
Stringle55
Joined Sep 7, 2017
10
It's not important to keep the switches, but I would like some indication (preferably on the button) of whether the signal is on or off. I will have a look online for switches with a built in light. Thank you very much!
12,193
A toggle or rocker switch with a separate light for each side will be hard to find. Can you add lights to the panel, one on each side of a switch?
Lighted momentary pushbutton switches are plentiful, but then you need something to electrically or electronically latch.
Where are you located?
Stringle55
Joined Sep 7, 2017
10
In the UK, I'm looking at using a flip-flop circuit to toggle the lights and 'latch' the momentary buttons (keep the lights on) which would be through one of the connections on the switch (normally there is one which turns on the internal light regardless of switch position). I did think of adding extra lights, but I only have a small projects box to use, so that might not be viable. Playing around with different ways to latch now, what's your preference?
38,596
How about two push-buttons controlling two relays?
One button would latch its associated relay while releasing the other.
It would use two DPDT relays and two SPST push-buttons as show below.
S1 and S2 represent the two PB switches.
Stringle55
Joined Sep 7, 2017
10
Looks good, but a little bit complicated as I'm not familiar with relay circuits! I've come up with a design that uses NOR gates to latch everything, and have added a reset switch for the latches.
When red is pressed, red lights up. When green is pressed, green lights up and red goes off. From there, red can't be pressed again until the system is reset, which turns either light off. I will try to send a picture of it in a bit!
Thank you
12,193
Is green ever pressed first?
If no, should it be locked out/ignored until red is pressed?
If yes, this can be done with a dual D flipflop, like a CD4013.
1 - CD4013
3 - pull down resistors
3 - switches
2 - 2N7000 transistors to drive the LEDs
1 - 0.1 uF decoupling capacitor
1 - 0.1 uF power-on-reset capacitor
Stringle55
Joined Sep 7, 2017
10
It could be, say if someone was a bit dozy and unprepared, but it should allow green to be pressed straight away, which then locks out red (i.e pressing red isn't a prerequisite for green to be pressed)
Stringle55
Joined Sep 7, 2017
10
That's a requirement I wasn't aware of, and the relay circuit I show allows either button to be pressed in any order.
How is the system reset?
There is a button that resets all of the circuits (as there is one for each outstation) regardless of which light is on for any of the circuits
12,193
First pass at post #8. This assumes that the total LED current for each color is below 100 mA and current limiting is external.
The power-on reset (POR) uses the clock inputs. This was necessary to get the interaction that lets the green output inhibit the red input without an additional logic gate and its package. The consequence is that the POR now is edge triggered rather than level dependent.
To get a power-on reset that is delayed slightly from power-on without adding more logic gates, the reset button doesn't actually reset anything until it is *released*. It will work even if the button tap is only 1 ms, but if you hold it down expecting the LEDs to go dark, they won't until the button is released.
Stringle55
Joined Sep 7, 2017
10
Yet more late information. Maybe a wiring diagram is in order.
Here is my first attempt at a circuit. I realise it's all digital on here, but don't know enough to turn it into a real design (with 12v power etc) so for now this is just a proof of concept. Any improvements to the design would be greatly appreciated!
38,596
Use AK's circuit in post #16.
It only uses one IC chip, while your circuit requires at least two.
That chip can be powered directly by the +12V.
