creating 'realistic' log pot taper with VCA
pgo1
Joined Nov 7, 2012
67
I'm making an amplifier with a VCA and I want to create a pot control that responds like a normal log pot. Obviously when you control the volume with a linear pot into the control port of a VCA, it never goes to 0 without altering how steeply the volume cuts off as you turn the pot.
I read elsewhere that a log pot is actually two tapers, a log taper and a linear taper which goes to 0 at the end of its range. My question is at what point of the taper does the linear taper start? Its a little difficult to measure this reliably with a physical pot
additionally, does anyone know a schematic for VCA control which does this? I can't have been the first..
Papabravo
Joined Feb 24, 2006
22,111
If I understand you correctly you want to create a voltage source that is a linear to log converter. In other words the output voltage is the logarithm of the input voltage. Did I get that correct?
38,790
A common way to get a quasi-log response from a linear pot is to add a resistor, with a value of 10-20% of the total pot resistance, from the wiper to ground.
Below is the LTs simulation of that configuration:
The output is plotted with a dB (log) scale, so a perfect log output would have a straight line.
The output is effectively logarithmic (for audio purposes) from about 10% to 90% of pot rotation.
Below 10% it drops off rapidly as the output approaches an attenuation of infinite dB at 0% rotation.
The value of R2 determines the output curve shape.
Here a 10% value for R2 gives a 50% pot rotation output attenuation of ≈-17dB.
A linear pot has an output of -6dB at 50% rotation, of course.
pgo1
Joined Nov 7, 2012
67
ah hmm i think some of you are misunderstanding what I mean.
I have a VCA which is scaled at -33mV / dB. If I use a linear pot to control the voltage to the CV control then at it's minimum the signal will not be 0V/-infdB, it will only be low and in some cases audible.
If I use a normal log pot as a volume control the signal will actually be 0V /-infdB (ok I know it's not infinity but it's small enough that it's buried in noise)
I want to make the VCA with a lin pot control behave like a log pot i.e. go to 0 at the end of the taper. I could make the linear control slope steeper which would result in a lower minimum but it would make the pot "feel" different.
I'm going to rephrase the question a bit - i heard that pot tapers are composites of more than 1 taper and I was planning on making a circuit which used a linear control voltage but "swaps" tapers (both linear voltages but one is "steeper") at low volume. I wondered at what point in the taper (at what gain in dB) i should swap between tapers to achieve my goal and retain a normal feel, and if anyone is familiar with any circuits which do this
Most log pots are just an approximation using three linear sections.
what are the three sections?
38,790
Not true.
Both types of pots go to 0V (wiper shorted to the end terminal) when they are at the zero position.
There is no difference between a log pot and an linear pot at that position.
Why do you think there is?
pgo1
Joined Nov 7, 2012
67
Not true.
you're still not understanding me. im not talking about a lin vs a log pot, im talking about *controlling a VCA* with a lin pot
38,790
And you don't seem to be understanding me.
I showed you in post #4 how to use a lin pot to generate a quasi-log output for your "VCA".
And the lin pot goes to 0V output at 0% rotation [which can't be shown on a dB (log) scale].
So what more do you want?
Ian0
Joined Aug 7, 2020
13,272
The output of the VCA is already log, why would you want to control it with a log pot?
A good VCA will go down to -90dB (provided you don't get crosstalk due to poor pcb layout, or coupling through the power supply etc.) How much attenuation do you need?
pgo1
Joined Nov 7, 2012
67
There's no need for the quotation marks - it's not euphemistically a VCA, it's an actual VCA
ill try and explain it another way. Attached is a schematic with a pot which goes from 0 to -5V and derives a CV from that which controls a VCA. Below are the dB responses of
green) plot of how a normal log pot behaves (more or less, I used your loaded lin pot solution for this)
red) the VCA output with the gain scaled to approximately how a normal log pot behaves - you can see that at minimum it's about -33dB, this isn't quiet enough
pink) what happens if i feed the green trace into the VCA, with a few component tweaks. it's fine, workable, but not exactly what I was asking. In my particular circuit (of which this is a smaller part) I don't want to alter the response of that pot because it needs to feed other things which need the linear response
With those plots in mind what I was asking with my original question is at what point in the end of the taper will the green curve start to go negative compared to the red i.e. when the gain quickly reduces to 0. I've obviously answered my own question here by plotting it so don't worry about answering that
Additionally, I wanted to know a circuit where I could sort of swap between responses, have the red plot all the way up to the end of the taper of the pot then swap to the green plot for the end - some kind of op-amp processing *after* the pot - and I was wondering if there are schematics for anything like that
Ian0
Joined Aug 7, 2020
13,272
Just use a linear pot and increase R1 to 68k.
You have only 1.1V control range, which will give you a maximum of 33dB attenuation. If you increase to 3.3V control range, you will get 100dB attenuation, and it will be perfectly logarithmic.
SSM2164 is a very good VCA.
pgo1
Joined Nov 7, 2012
67
Is there a reason for this obstinacy?
Having -50dB in the middle of the pot is not usable. Plus, i use this in different contexts so it's an interesting general question for me. nothing to do with obstinacy, that's was the original question and it's still the question.
Ian0
Joined Aug 7, 2020
13,272
First decide on your minimum and maximum points, and set R1 accordingly. The pot will always be at 0V and 5V at the ends of its range. Then decide on what attenuation you need at the centre, and calculate the value of resistor to put between wiper and one end of the pot.
38,790
That's a new requirement I wasn't aware of (would have been nice to know at the beginning).
So I'll let others guide you on your quixotic quest. :rolleyes:
