I have confirmed that the power feed to the dome light is coming from the Instrument Cluster, YE/LB also called, Interior Lighting Relay. I haven't taken the instrument cluster apart to see if the relay is welded or the MPU is commanding it "on". Not nice to get into the instrument cluster circuit board. The only way is to nibble away the white plastic cover on the back. It can't be disassembled because you would have to tear all the needles off the gauges to split the case.If you can track down where the signal originates and if in fact it is a simple shorted transistor in a control module I would like to know about it. It might be a rather profitable sideline business to get into fixing them!![]()
Don't know how hard it is to get to what they are calling the 'body security module'. but it looks like if you cut the wire colored "pink/orange and then jumpered that wire over to the one colored 'red/orange" that would do the unlock all doors at once when transmission is put in park. All of the locks are connected by the pink/black wire that is the one that should lock them all at once. And I'm assuming you know that the wire colors are listed as the first one being the main color and the one after the slash is a colored stripe on the wire.I must have looked right past your first post. The following diagram is the only one that has anything to do with the door locks, so maybe it will be helpful.
It looks to me like the Interior Lighting Relay is a 12 legged, gull wing, surface mount chip, that could not be touched without destroying all the gauge needles if you were a left handed surgeon with 3 wrists on each arm and had a squad of tiny soldering ants. Ima guess this one is going to be an external fix...if I can think of a way to do it. Plenty of places to access wires, but printed circuit boards are very well guarded. Our Father Who Art In Detroit really, really, wants me to pay $1000 to get the dome lights to work.if in fact it is a simple shorted transistor in a control module I would like to know about it.
It isn't much of a pain, yet. I haven't had a, "tow it to the Dealership and pay a ransom" event...yet.Lifelong Ford owner so I know your pains well.
Why not put a toggle switch in the feed wire to the lamp? Taking the windshield trim off of the A pillar on the drivers side and drilling a hole for the switch would make it easy to access when getting in or out. One company I worked for years ago made those trim panels for Ford, they had a couple of screw holes for mounting. Don't know if yours does though.external fix...if I can think of a way to do it
Why don't I buy one of those battery operated LED lamps intended to be installed in a closet?Why not put a toggle switch in the feed wire to the lamp?
