Thank you for reading!
I am interested in building DC / DIY chargers and battery packs!
I want to create a battery pack and charger for specialized radio battery applications using 18650’s
My basic question is if / how this will work:
I want to use 18650’s to charge radio(s) – of course, these radios have specific power requirements
My idea was to use a DC car charger and cables, cut the leads, and use it to charge from a battery back and/or 18650’s.
I know that I can get the voltage correct or close from attaching 18650 batteries in series, BUT MY MAIN QUESTION IS WILL THIS WORK WHEN CONSIDERING THE AMPERAGE. (see pictures)
The car charger expects 11.7 - 15.9 volts, so no problem – I can make an 18650 x 4 battery pack, but if I use this DIY battery pack to charge my radio batteries, can anyone comment on how the amperage will affect the system?
I understand that a car adapter will have a massive variance in AMPS, but in theory would this work if the charger and wires are designed for 12V car applications?
If the voltage is correct or close and I attach a battery pack to this adapter / charger, would this work and/or would it be a good idea? Clearly, I can get the voltage correct, but what about the amperage?
Thanks,
Dave
Thanks,
Dave
