counter 2-3-1-0 using jk flip flops
sweetpea1543
Joined Nov 19, 2020
5
Hello all!
I am trying to complete a circuit that that outputs the sequence of 2-3-1-0 using the clock on my bread board. I am supposed to jk flip flops and a seven segment display. I have a ciruit that i think works but i am confused on how to use the 7 seg display with only one output? I have attached my circuit below. Thanks!
dl324
Joined Mar 30, 2015
18,490
Your circuit has 2 outputs and the display appears to have 4. What do you think you need to do with the unused inputs?
Your drawing style is atrocious. Unnecessary wire bends, scenic routes, wires on top of symbols, unnecessary connection dots. How would you feel if someone asked you to read something like that?
ericgibbs
Joined Jan 29, 2010
21,622
hi sweetpea,
Welcome to AAC.
I guess you are just starting out studying electronics.?
Have you been taught any method of drawing circuits, it can be difficult at the start but you could easily pick it up.
E
sweetpea1543
Joined Nov 19, 2020
5
hi sweetpea,
Welcome to AAC.
E
thanks for asking... unfortunately no i have not. This class that im in is kind just everyone being thrown off into the deep end :(. ive tried my best at doing it but clearly there is a certain method of drawing circuits that your supposed to follow. None of which ive been taught.
ericgibbs
Joined Jan 29, 2010
21,622
hi,
OK, I understand.
If you have to display the Count down on a LED, you need a LED driver IC.
This PDF shows one example, there are many more.
Have you been told which IC's you can use in your project.?
E
Update:
This is a clip from circuit that uses switches, yours will be the JK flip flops
dl324
Joined Mar 30, 2015
18,490
The preferred flow is left to right and top to bottom; with consideration for the items I mentioned above.
Here's an example of a down counter:
Printing from logisim gives something without the grid (and the colors):
What school are you attending?
EDIT: You're using the display with 8 inputs. The hex display has an input with the address lines bused:
sweetpea1543
Joined Nov 19, 2020
5
again please excuse the way this is designed but i have made progress. The only state that i am missing is now 0. Please see the circuit below
sweetpea1543
Joined Nov 19, 2020
5
dl324
Joined Mar 30, 2015
18,490
Why are you using a display that requires a decoder? I interpreted the requirement to be to design a counter with a 2-3-1-0 sequence.
ericgibbs
Joined Jan 29, 2010
21,622
hi sp,
As you may know a 7 segment LED's segments are named a,b,c,d,e,f,g
Please mark your circuit LED segments with these letters, so that we can check your circuit.
E
Update:
This is the segment combination you need to show 3 then 2 , 1 and 0
dl324
Joined Mar 30, 2015
18,490
Yes youre correct. However we are supposed to display the output of the sequence on a 7 segment display
This display has 2 inputs. The input on the left is a bus for the 4 inputs; don't know what the other pin is for - it doesn't seem to be needed.
EDIT: The input on the right is for the decimal point.
Check your counter design logic. I was able to make the counter without using any additional gates.
