Asynchronous BCD Downward Counter using JK Flip flops
highf15e
Joined Apr 30, 2021
Hello. I am having a simple problem but couldn't help to solve it, I am doing a Asynchronous BCD with JK Flip flop, but I used to create an upward ones, and I don't know how to revert it or make it downward instead of upward. I also tried to use NOT gate, but didn't work. Below is the screenshot of my work. Hope you could help me with this. Thanks so much..
highf15e
Joined Apr 30, 2021
Welcome to AAC!
Post your truth table and Kmaps.
Regarding your schematic style. You have the flip flops drawn sideways and ground always points down.
Hello sir, to be honest I don't know yet how to create the KMaps, and currently practicing in creating perfect truth table.
Regarding with the position of my JK flip flops, I am sorry for that cause it was a given instruction of my professor, not including the ground. Thank you so much sir.
dl324
Joined Mar 30, 2015
18,467
My fault. I thought you were designing a synchronous counter. You'll learn about synchronous counters when you learn about the limitations with asynchronous designs.
What do you think is required to have the counter go from 9 to 0 0 to 9?
EDIT: corrected count order
ericgibbs
Joined Jan 29, 2010
21,572
hi 15e,
You know what the Q outputs are doing during the count sequence, what do you think the NOT Q outputs are doing during the count sequence.??
E
Update:
For your UP counter can you complete the missing 0s and 1s in this Count Table.?
I have done the first 5 states.
E
RBR1317
Joined Nov 13, 2010
715
A BCD down-counter means that the count will proceed from a count of nine down to zero. Should the count stop at zero or cycle back to nine? Look at a table of the individual bit states as the count goes from nine to zero. Note that the "A" bit changes its value for each clock pulse, i.e. alternating red and green transitions. Also note that a green transition always triggers a transition to the more significant bit on the left, but a red transition never does. (hint: that is a clue)
But the previous observation does not apply once the down counter reaches zero. So, have you determined what is supposed to happen once the down-counter reaches zero?
highf15e
Joined Apr 30, 2021
Good day sir(s)! First of all I just want to thank you all for giving me such tips and advises for me to solve my simple problem and to improve my work from self-learning, and I've got a solution already for the said problem, because of all your given tips and clues.
As it shows I have just inserted 'NOT gates' (Inverter) to all the 'Clock' for it the switch would turn into NGT.
So from its original counting: 0 (Zero) to F, it turns out now to F to 0 (Zero), and then resets back to F and so on...
I don't know if this is the right way or not, but I found this way solved my problem. Anyways, I'm doing the truth table for this and I don't have any idea on how to create the right one. Again, thank you so much sir(s) and madam(s) 'if any'.
dl324
Joined Mar 30, 2015
18,467
The inverters aren't needed because the flip flops have both polarity outputs. U9 isn't needed either.
Do you know the rule for connecting flip flops to get them to count up or down asynchronously?
As far as I know, there's no (widely taught) formal design process for asynchronous counters. You just use the clock and output rules to get the counter to count in the right direction and decode counts to use for the preset/clear inputs.
EDIT: add (widely taught) qualification.
ericgibbs
Joined Jan 29, 2010
21,572
hi 15e,
Did you check as suggested how the /Q outputs where changing as the Q outputs counted Up.
Look at the sequence and let me know what you see.
BTW: it's not a BCD counter, it counts from 0 to 15, so it is Binary counter.
E
