Hello KeithWalker,What is a DSK? Is it digital shift keying?
Clues are always helpful.
Thank you!Hello there welcome to AAC!
You can try digikey Mauser Newark element 14, just punch in the numbers.
I only say this because of your description of the capacitor bravo!
It'll be a breeze for you. Here's your diode.
Your logic is sound to me. However, I extracted the value from a data sheet that labeled it picofarad. The data sheet also indicated the 6 stands for 6 volt. I may have to double check.A capacitor labeled labeled 106 means 10 followed by 6 zeros worth of picofarads. That's 10E6 x 1E-12 = 10E-6 or 10 uFd.
I would like to correct an incorrect information.
The capacitor listed is labeled 106 pF which is 10E6 x E-12 => 10E-6 or 10 uF.
Thank you!
Thanks!
Hello Papabravo,
You are absolutely correct!
Thanks!
by Jeff Child
by Jeff Child
by Aaron Carman
by Jake Hertz
