Could you check this circuit please? 741 Pre Amp(Student / Easy)
Scott Walker
Joined Feb 8, 2016
6
I need to create an inverted 741 pre amplifier circuit on a vero board
I found this diagram on the internet but it wasnt inverted so I used photoshop to swap pin 2 and 3 so it was correct.
I have a number of questions:
Firstly are the polar directions correct on this diagram since the change?
I don't know how AF in and out are connected, for example would C3 connect to a wire, connect that to AF out and then go to ground?
Thanks,
I am an audio student at university but one of the modules is Electronics in which I struggle with sometimes
Veracohr
Joined Jan 3, 2011
783
C1 and C3 should be at least 10 times larger unless you're not concerned with low frequencies.
Try a better opamp than a 741. NE5532 are used a lot in audio circuits and are good.
Scott Walker
Joined Feb 8, 2016
6
C3 should go between the output of the opamp and VR1 otherwise the low frequency response will change with the level setting.
Thanks for the reply, I have a set list of components I need to use.
What about the way this diagram shows AF in and out, how would that be hooked up?
Cheers
Veracohr
Joined Jan 3, 2011
783
I edited my reply, I was wrong about C3.
AF in and out connectors will have two contacts: signal and common (ground). All common connections connect together, including the opamp ground on pin 4.
tindel
Joined Sep 16, 2012
939
Since this appears to be homework - I won't give answers, but will drop hints.
Be careful driving a capacitive load with an opamp - it can lead to instability (oscillations). I can think of a couple better ways to vary the output magnitude... although what you have done will work (assuming you figure out how to drive a capacitive load with your opamp). The 741 may be able to drive capacitive loads... I forget and it's been nearly 10 years since I used a 741.
I disagree that C3 is a good value. C3 is only a good value if the trim pot is dialed in one direction - or you are adding a variable filter.
Don't forget to decouple your power rails.
Scott Walker
Joined Feb 8, 2016
6
So am I right in thinking one connection will go at the start of the circuit, making it's way to pin 2 and the other connection simply going to ground?
Cheers
12,279
With C3 where it is, the opamp is putting a constant 7.5Vdc across the pot regardless of the signal amplitude or pot adjustment. While the 741 can do this, there is no good reason for it. I suggest moving C3 so it is in series between 741 pin 6 and the top of VR1, positive end toward pin 6.
The input and output components form two 80 Hz high-pass filters. To improve the circuit bass response, increase C1 and C3 to 10 uF.
#12
I see another likely problem area. When you dial an op-amp up to a gain of 100, they have a bad tendency to pick up noise. Put this in a metal box to shield the circuits from electronic noise in the air.
