Could this circuit be evaluated
27,507
Yes, it is entirely possible that "anyone" can explain those sections of the circuit. They appear to provide the needed functions to deliver a useful output from the sensor.
Sbala
Joined Feb 4, 2019
5
Hi Bill thank you for your quick response. yes it is an output of a sensor. but could you explain the functions of each circled block individually.
27,507
Block 2 is a differential amplifier that also delivers a non-differential output. For block 3 yiou have excluded a number of parts that are important to the functioning of the system. That transistor T4, changes the gain at some selected switch point, while U1 and associated capacitors are functioning as some sort of comparator. Section 4 includes a dual voltage follower with added DC offset, and section 5 looks like it is probably a current output stage. Upon additional examination, section 3, including the transistor and diodes, might also be a voltage to frequency converter. I have not gone through a detailed evaluation of that part.
Sbala
Joined Feb 4, 2019
5
Thank you so much for your time. very much appreciated.
