Converting this UNO code to Nano problem
Mozee
Joined Jul 23, 2016
87
I have used this code for a function generator project utilizing the AD9851 module and a rotary encoder and It works flawlessly using the UNO,
Now that I want to build a small plastic box for it and fit everything in I want to use the Smaller Nano for this project and to be honest I have very very little Arduino programming knowledge so any help is highly appreciated
The original Uno code is
Main code by Richard Visokey AD7C - www.ad7c.com
Revision 2.0 - November 6th, 2013... ever so slight revision by VK8BN for AD9851 chip Feb 24 2014
// Include the library code
#include <LiquidCrystal.h>
#include <rotary.h>
#include <EEPROM.h>
//Setup some items
#define W_CLK 8 // Pin 8 - connect to AD9851 module word load clock pin (CLK)
#define FQ_UD 9 // Pin 9 - connect to freq update pin (FQ)
#define DATA 10 // Pin 10 - connect to serial data load pin (DATA)
#define RESET 11 // Pin 11 - connect to reset pin (RST)
#define pulseHigh(pin) {digitalWrite(pin, HIGH); digitalWrite(pin, LOW); }
Rotary r = Rotary(2,3); // sets the pins the rotary encoder uses. Must be interrupt pins.
LiquidCrystal lcd(12, 13, 7, 6, 5, 4); // I used an odd pin combination because I need pin 2 and 3 for the interrupts.
int_fast32_t rx=1000000; // Starting frequency of VFO =============================================================================( )
int_fast32_t rx2=1; // variable to hold the updated frequency
int_fast32_t increment = 1000000; // starting VFO update increment in HZ.
int buttonstate = 0;
String hertz = "10 Hz";
int hertzPosition = 5;
byte ones,tens,hundreds,thousands,tenthousands,hundredthousands,millions ; //Placeholders
String freq; // string to hold the frequency
int_fast32_t timepassed = millis(); // int to hold the arduino miilis since startup
int memstatus = 1; // value to notify if memory is current or old. 0=old, 1=current.
int ForceFreq = 1; // Change this to 0 after you upload and run a working sketch to activate the EEPROM memory. YOU MUST PUT THIS BACK TO 0 AND UPLOAD THE SKETCH AGAIN AFTER STARTING FREQUENCY IS SET!
void setup() {
pinMode(A0,INPUT); // Connect to a button that goes to GND on push
digitalWrite(A0,HIGH);
lcd.begin(16, 2);
PCICR |= (1 << PCIE2);
PCMSK2 |= (1 << PCINT18) | (1 << PCINT19);
sei();
pinMode(FQ_UD, OUTPUT);
pinMode(W_CLK, OUTPUT);
pinMode(DATA, OUTPUT);
pinMode(RESET, OUTPUT);
pulseHigh(RESET);
pulseHigh(W_CLK);
pulseHigh(FQ_UD); // this pulse enables serial mode on the AD9851 - see datasheet
lcd.setCursor(hertzPosition,1);
lcd.print(hertz);
// Load the stored frequency
if (ForceFreq == 0) {
freq = String(EEPROM.read(0))+String(EEPROM.read(1))+String(EEPROM.read(2))+String(EEPROM.read(3))+String(EEPROM.read(4))+String(EEPROM.read(5))+String(EEPROM.read(6));
rx = freq.toInt();
void loop() {
if (rx != rx2){
showFreq();
sendFrequency(rx);
rx2 = rx;
buttonstate = digitalRead(A0);
if(buttonstate == LOW) {
setincrement();
// Write the frequency to memory if not stored and 2 seconds have passed since the last frequency change.
if(memstatus == 0){
if(timepassed+2000 < millis()){
storeMEM();
ISR(PCINT2_vect) {
unsigned char result = r.process();
if (result) {
if (result == DIR_CW){rx=rx+increment;}
else {rx=rx-increment;};
if (rx >=70000000){rx=rx2;}; // UPPER VFO LIMIT
if (rx <=1){rx=rx2;}; // LOWER VFO LIMIT
// frequency calc from datasheet page 8 = <sys clock> * <frequency tuning word>/2^32
void sendFrequency(double frequency) {
int32_t freq = frequency * 6442560000./180000000; // note 180 MHz clock on 9851. also note slight adjustment of this can be made to correct for frequency error of onboard crystal
for (int b=0; b<4; b++, freq>>=8) {
tfr_byte(freq & 0xFF);
tfr_byte(0x001); // Final control byte, LSB 1 to enable 6 x xtal multiplier on 9851 set to 0x000 for 9850
pulseHigh(FQ_UD); // Done! Should see output
// transfers a byte, a bit at a time, LSB first to the 9851 via serial DATA line
void tfr_byte(byte data)
for (int i=0; i<8; i++, data>>=1) {
digitalWrite(DATA, data & 0x01);
pulseHigh(W_CLK); //after each bit sent, CLK is pulsed high
void setincrement(){
if(increment == 1){increment = 10; hertz = "10 Hz"; hertzPosition=5;}
else if(increment == 10){increment = 50; hertz = "50 Hz"; hertzPosition=5;}
else if (increment == 50){increment = 100; hertz = "100 Hz"; hertzPosition=4;}
else if (increment == 100){increment = 500; hertz="500 Hz"; hertzPosition=4;}
else if (increment == 500){increment = 1000; hertz="1 Khz"; hertzPosition=6;}
else if (increment == 1000){increment = 2500; hertz="2.5 Khz"; hertzPosition=4;}
else if (increment == 2500){increment = 5000; hertz="5 Khz"; hertzPosition=6;}
else if (increment == 5000){increment = 10000; hertz="10 Khz"; hertzPosition=5;}
else if (increment == 10000){increment = 100000; hertz="100 Khz"; hertzPosition=4;}
else if (increment == 100000){increment = 1000000; hertz="1 Mhz"; hertzPosition=6;}
else{increment = 1; hertz = "1 Hz"; hertzPosition=5;};
lcd.setCursor(0,1);
lcd.print(" ");
lcd.print(hertz);
delay(250); // Adjust this delay to speed up/slow down the button menu scroll speed.
void showFreq(){
millions = int(rx/1000000);
hundredthousands = ((rx/100000)%10);
tenthousands = ((rx/10000)%10);
thousands = ((rx/1000)%10);
hundreds = ((rx/100)%10);
tens = ((rx/10)%10);
ones = ((rx/1)%10);
lcd.setCursor(0,0);
lcd.print(" ");
if (millions > 9){lcd.setCursor(0,0);}
else{lcd.setCursor(1,0);}
lcd.print(millions);
lcd.print(".");
lcd.print(hundredthousands);
lcd.print(tenthousands);
lcd.print(thousands);
lcd.print(".");
lcd.print(hundreds);
lcd.print(tens);
lcd.print(ones);
lcd.print(" Mhz ");
memstatus = 0; // Trigger memory write
void storeMEM(){
//Write each frequency section to a EPROM slot. Yes, it's cheating but it works!
EEPROM.write(0,millions);
EEPROM.write(1,hundredthousands);
EEPROM.write(2,tenthousands);
EEPROM.write(3,thousands);
EEPROM.write(4,hundreds);
EEPROM.write(5,tens);
EEPROM.write(6,ones);
memstatus = 1; // Let program know memory has been written
The error I'm getting when trying to upload to my NANO
In file included from /Users/mirxan/Documents/Arduino/Arduino-AD9851-DDS-Direct-Digital-synthesizer-Signal-Generator-master/Arduino DDS 2/AD9851_LCD_ROTARY_WMENUS/AD9851_LCD_ROTARY_WMENUS.ino:9:0:
/Users/mirxan/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/libraries/EEPROM/src/EEPROM.h:43:30: warning: type qualifiers ignored on function return type [-Wignored-qualifiers]
operator const uint8_t() const { return **this; }
/Users/mirxan/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/libraries/EEPROM/src/EEPROM.h:92:26: warning: type qualifiers ignored on function return type [-Wignored-qualifiers]
operator const int() const { return index; }
/Users/mirxan/Documents/Arduino/Arduino-AD9851-DDS-Direct-Digital-synthesizer-Signal-Generator-master/Arduino DDS 2/AD9851_LCD_ROTARY_WMENUS/AD9851_LCD_ROTARY_WMENUS.ino: In function 'void loop()':
/Users/mirxan/Documents/Arduino/Arduino-AD9851-DDS-Direct-Digital-synthesizer-Signal-Generator-master/Arduino DDS 2/AD9851_LCD_ROTARY_WMENUS/AD9851_LCD_ROTARY_WMENUS.ino:77:26: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
Archiving built core (caching) in: /var/folders/1y/gz925xkn7hbfdksl2kvf66ch0000gn/T/arduino_cache_84420/core/core_arduino_avr_nano_cpu_atmega328_fa1b08b34ccd52872ebff4bfcb4298c8.a
Sketch uses 7050 bytes (22%) of program storage space. Maximum is 30720 bytes.
Global variables use 219 bytes (10%) of dynamic memory, leaving 1829 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "/dev/cu.usbmodem1421": No such file or directory
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Invalid library found in /Users/mirxan/Documents/Arduino/libraries/RotarySource: /Users/mirxan/Documents/Arduino/libraries/RotarySource
AlbertHall
Joined Jun 4, 2014
12,651
The errors are compilation errors not upload problems and as far as I know any code that works on a uno will also work on a nano.
Try selecting the uno and just verify the code. If you get the same errors then it's nothing to do with the change to nano.
Mozee
Joined Jul 23, 2016
87
It works with UNO , just not with the Nano!
and I do have 3 Nano and it worked with non of them! what could be wrong?
AlbertHall
Joined Jun 4, 2014
12,651
For me, the code above gives compilation errors whether I compile for uno or nano.
Change '#include <rotary.h>' to '#include <Rotary.h>' then it compiles correctly for either platform.
george4657
Joined Apr 12, 2016
15
The cheap china Nanos use the ch340 usb chip not the same chip as the Uno so it should show as a different port number than the Uno.
As above I had to "Change '#include <rotary.h>' to '#include <Rotary.h>'" also as Albert pointed out to get it to verify for either board.
