Converting Nokia 5110 SW CODE to HW CODE in Oshonsoft
camerart
Joined Feb 25, 2013
3,853
I have a program for Nokia 5110 screens written in Oshonsoft BASIC, and using it's SW to WRITE to it. [18F46K20 8MHz XTL 5110 HC12 090722 1500 and fontsml ]
I also have a program written in Oshonsoft, but using HW CODE (SSPBUF). The HW program is too large to post.
I need to integrate the 5110 CODE into the HW program. For me this is a bit too difficult, as I don't know where to start. I think the SW program needs to be converted first, then I can integrate.
Can someone give me clues how to approach this change please.
Camerart.
camerart
Joined Feb 25, 2013
3,853
Using the LINK CODE in #2, the screen shows 1/2 BYTE along a line, then scrolls round clears the first 1/2 BYTE line, and replaces it with the bottom 1/2 BYTE like this:
In the CODE, there seems to be bits missing, e,g, (sc), (cmd) (data), is this true?
C
camerart
Joined Feb 25, 2013
3,853
I can see that there are a lot of SPI lines of SW CODE, which somehow have to be changed to the HW SSPBUF method. Gulp!
So I've reverted to working on the CODE and fontsml in #1, it looks like it's most suitable as it has a FONT.
C
ericgibbs
Joined Jan 29, 2010
21,575
hi C,
The Manual states:
(1) can be changed by setting SPICLOCK_STRETCH parameter.
SPIPrepare,SPICSOn,SPICSOff,SPISend,SPIReceive,SPISendBits,
SPIPREPARE statement (no arguments) will prepare interface lines for SPI communication. SPICSON and SPICSOFF statements will enable/ disable the ChipSelect line of the interface.
@camerart
Hi C,
You must have SPIPrepare statement in the program if you intend using SPICSON and SPICSOFF
camerart
Joined Feb 25, 2013
3,853
hi C,
The Manual states:
@camerart
Hi C,
Hi E,
I'm trying to write HW, and as SPIPREPARE, SPICSON etc are all software, I've removed them. I now need to replace them with a HW version.
NOTE: the PIC is in MASTER MODE
EDIT: I now see that I was duplicating the 5110 screen chip select, by using both LCD_CS and SPICSON.
Thanks.
C.
camerart
Joined Feb 25, 2013
3,853
Update:
I followed the link in #2 to ETO, and 'I' updated his CODE for me, and after a bit of blind twidling, I got it to show this:
Cheers, C.
