Converter DAC... how works
akkex eliu
Joined Jul 21, 2018
Hi guys!! I´m doing a homework of electronics if anyone can help me to realize it or to see the theory questions i can try to do it.
1)Two DACs are connected in the manner indicated in figure 1:
a)Deduce Vo based on Vb and B (t).
b)For what values of B is V0 defined?
2)Explain in detail the operation of a WATERFALL converter. Use a block diagram indicating how to carry out the conversion.
3)The digital conversion of a signal with the following characteristics is desired: Maximum frequency: 10 Mhz. Signal noise ratio S / N = 60dB. a) How many samples should be taken? b) What is the minimum number of bits of the conversion? Argue your answers
WBahn
Joined Mar 31, 2012
33,126
You need to show your best attempt to work your homework. That gives the folks here a starting point from which to help guide you along your path from where you are stuck to a correct solution.
