Convert Sawtooth to square wave
DebiP
Joined Jul 27, 2021
18
HI Please, can anyone help in realising a circuit (Ltspice) to convert a saw tooth signal to a square waveform. Please, see below for the image.
The green spikes are the original oscillation signal. And blue is the envelope signal. I need to convert the blue envelope to a square wave.
DebiP
Joined Jul 27, 2021
18
HI Thanks
But the oscillation signals are from a sensor which generates spikes. I need to convert a bunch of spikes to a square wave.
DebiP
Joined Jul 27, 2021
18
Schmitt trigger?
Thanks.. I think so.. A Schmitt trigger may work. Please, can I get a schmitt trigger circuit for a sawtooth wave form with similar voltage range. I need the square wave to be between 0 and 1. The frequency is between 7-20Hz.
IgorZg
Joined Jul 10, 2021
7
Now I take look more closely, for such low voltage schmitt trigger digital IC won't work. But what will work is opamp as comparator.
IgorZg
Joined Jul 10, 2021
7
I dont't know nothing about rest of your circuits, about problem yo try to solve. The comaparator is the part of basics, there are plenty of educational material out there about.
38,859
Do you need to detect every triangle peak even if it only returns to a slightly smaller voltage than the peak (example below)?
What is generating the triangle wave?
38,859
I would like to bunch the triangular peaks close to each other.
Okay.
Then a comparator such as the LM339/393 with input biased to the voltage you want to detect should work for you.
Do you know what the low voltage is, above which you want to generate a high for the square-wave?
LesJones
Joined Jan 8, 2017
4,544
I don't know what you want the square wave for but here is a suggestion that will give a square wave but it is probably half the frequency you require. Differentiate the positive going edge of the sawtooth wave and use it to toggle a flipflop. You will probably have to amplify to deal with when the positive edge is of a low amplitude.
The problem you have generating the square wave that you require is there is no way to know when to generate the negative going edge of the square wave until the next positive edge of the sawtooth. I think you could generate a slightly delayed version of the square wave you require using a microcontroller that measured the time between positive edges of the sawtooth. It could then divide this value by 2 to create the negative edge of the square wave. The microcontroller would make the positive edge of the square wave when the positive edge of the sawtooth occurred and create the negative edge after half the gap between the previous two positive edges. This would mean the generated square wave would be one cycle behind the sawtooth waveform.
Les.
LowQCab
Joined Nov 6, 2012
5,102
You would get much better answers if You would explain what the overall
problem is that You are trying to find a solution for.
And don't forget to provide Schematics,
words can only convey a limited amount of information.
Ian0
Joined Aug 7, 2020
13,291
Perhaps you could draw on the original waveform the square-wave you are hoping to generate, then we could probably work out how to do it.
35,222
Forget the spikes, the sawtooth waves and a solution for a moment.
Tell us what is generating the signal and what it is you are trying to measure or do with the signal.
DebiP
Joined Jul 27, 2021
18
Okay.
Thanks for the response, the low threshold will be about >200mv
DebiP
Joined Jul 27, 2021
18
The spikes are generated by a sensor which oscillates on applying a voltage pulse. The spikes are stochastic and can vary in amplitude. I have managed to create an envelope across the the spikes. The envelope are a sawtooth wave. I wish to convert these sawtooth envelope to square wave.
DebiP
Joined Jul 27, 2021
18
I would have provided a schematic if I had one. Sorry. At this moment. i have the generated sawtooth envelope. I need a circuit which can convert these to a square wave.
35,222
This tells us nothing that you have not told us already.
Thanks for nothing.
Sorry, I have nothing else to offer.
