Convert 2 AAA with 3v AC adapter
FLDS
Joined Dec 13, 2017
11
Hello All,
I am confused and need some help. I have a baggage scale unit (bsu) using 2 AAA batteries. I am trying to convert it with the help of a adapter/transformer Input 110v, output 3v – 1Amp.
I built dummy batteries (db) out of 3/8 dowels, wired each db with screw on either side. I connected these db to the adapter and test them with a multi meter I get 3.5v. I install the same in the bsu.
After I install the 2 db, into the bsu compartment (just like the 2 AAA batteries). I turn on the bsu, I get no power. With the pos – neg wire still connected to the adapter and the 2 db installed the bsu compartment, I test the voltage, I get 0.12v, how is this possible, am I doing something wrong?
Do I require 2 diodes rectifier and a capacitor for this to function? If yes, what are the sizes that I require to purchase?
Hope I have explained it correctly, did my best. hope you understand. Your help would be appreciated.
Thanks in Advance
BobTPH
Joined Jun 5, 2013
11,678
You have the two terminals of each battery shirted together. Why? When installed in the battery compartment, this is creating a short across the supply.
FLDS
Joined Dec 13, 2017
11
Hi BobTPH,
Thanks for your response, That's the reason I said I am confused. Can you please tell me where I am going wrong. If you can correct the diagram I would appreciate. Thanks
Audioguru again
Joined Oct 21, 2019
6,826
Your diagram shows shorted batteries but I think they are not batteries, instead they are shorted wooden dummy batteries so that you can solder the adapter output wires to them.
Get rid of the shorting wires that might have destroyed the adapter.
FLDS
Joined Dec 13, 2017
11
Hi Audioguru,
Thank you for your response. I got rid of the short wires. It is now working.
FLDS
Joined Dec 13, 2017
11
Thank you all for your responses and help. The unit is now working.
I greatly appreciate what you guys are doing in the community. You people are the best.
I thank this forum too.
