The circuit I’m going off of is listed here http://www.thatcorp.com/datashts/dn02.pdf I had my circuit much closer to this and it wasn’t working, so I’ve strayed a bit by adding the divider for the control voltage in front of the buffer, and adding R7 and C8 (47R and 2.2n) which I got from another THAT design note.
So far I haven’t been able to get any signal from the output. I’ve tried biasing the VCA in a couple different ways but have had no luck. This and the single rail power that I’m using are maybe the two things I’m most suspicious of. I’ve also referenced their page with pedals made from their Analog Engine, which has a Voltage Reference going into EC- ; not sure how that's working, tried but failed.
( http://www.thatcorp.com/pedals/4316 Simple Limiter r00.1.pdf )
