Controlling the Charging Current With the Help of microcontroller
H@rsh
Joined Oct 22, 2024
Hey There,
I want to build a battery charger . i want to cutoff the charging current coming from the solar panel if my battery is charged . With the help of some mosfet and microcontroller. Can Anyone help me with this idea how i can do this . If my Battery Voltage Reaches to 13 Volt then Charging Current Should be zero and if it is around 12.7 or 12.8 then it should be slow charging . with minimum current required.
