controlling reset pin of A6 gsm
vtc
Joined Apr 3, 2018
37
Iam using A6 Gsm module with arduino uno to send and receive messages
I need to reset the module from the code,i read the datasheet and find the following for reset pin
But i don't understand what NMOS control ,could anyone explain it>
A6 Datasheet
Regards
Irving
Joined Jan 30, 2016
3,887
What I think its trying to say is that you need to pull this below 0.05v to ensure it resets the module, and when not resetting you must have very low leakage, therefore use an N-channel MOSFET rather than a transistor.
eg in circuit below, D11 HIGH pulls \RESET down to 1mV, D11 LOW, leakage is <0.5uA
jpanhalt
Joined Jan 18, 2008
11,087
It is hard to decipher that instruction. My impression is that pulling the pin low creates a reset. The 70 mA current seems strangely large. Maybe 70 uA is meant?
Checked a device that has similar capabilities (SIM808 Module GSM GPRS GPS). Its datasheet describes reset a little better (See: Attached pdf, page 27).
Irving
Joined Jan 30, 2016
3,887
Yes, I looked at a couple of other devices, but they all seem to have fairly normal logic levels. You may well be right about the 70mA -> 70uA, that makes more sense, but needing <0.05v is unusual. The circuit I show, with that particular MOSFET Rds_on < 180mOhm @ 1mA Ids, Vgs=3v, meets that requirement easily.
jpanhalt
Joined Jan 18, 2008
11,087
I agree, the mosfet is safer, if the reset current is really 70 mA. The datasheet is pretty vague about such values, except apparently the whole device can require up to 2 A. My comment was of course was based on the comment about using a GPIO in the other device.
Maybe the TS can confirm with tech service at the manufacturer (Ai ).
Irving
Joined Jan 30, 2016
3,887
Well the MOSFET I suggested will easily handle 70mA, and there are no overheating concerns. Still seems high, poor design I guess, maybe that']s why they are discontinuing it.
vtc
Joined Apr 3, 2018
37
Can i use any mosfet transistor ?
I appreciate your effort
vtc
Irving
Joined Jan 30, 2016
3,887
It must be a logic level MOSFET
Gate threshold Vth <2v
Drain current Max Ids(max) >200mA @ Vgs=3v
On resistance Rds < 200mOhm @ Vgs=3v
