Hi, I want to turn on/off passive buzzer for 2 seconds time. Buzzer detail given here https://www.thegeekpub.com/wiki/sensor-wiki-ky-006-passive-piezo-buzzer-module/
I followed given link and wrote my own code for PIC18F45K80.
When I run following code Buzzer gives sound continuously
What should I do in code to turn on/off passive buzzer for 2 seconds?
C:
// PIC18F45K80 Configuration Bit Settings
#define _XTAL_FREQ 20000000
// CONFIG1L
#pragma config RETEN = ON // VREG Sleep Enable bit (Ultra low-power regulator is Enabled (Controlled by SRETEN bit))
#pragma config INTOSCSEL = LOW // LF-INTOSC Low-power Enable bit (LF-INTOSC in Low-power mode during Sleep)
// SOSCSEL = No Setting
#pragma config XINST = OFF // Extended Instruction Set (Disabled)
// CONFIG1H
#pragma config FOSC = HS2 // HS oscillator (high power, 16 MHz-25 MHz
#pragma config PLLCFG = OFF // PLL x4 Enable bit (Disabled)
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor (Disabled)
#pragma config IESO = OFF // Internal External Oscillator Switch Over Mode (Disabled)
// CONFIG2L
#pragma config PWRTEN = ON // Power Up Timer (Enabled)
#pragma config BOREN = OFF // Brown Out Detect (Disabled in hardware, SBOREN disabled)
#pragma config BORV = 0 // Brown-out Reset Voltage bits (3.0V)
#pragma config BORPWR = LOW // BORMV Power level (BORMV set to low power level)
// CONFIG2H
#pragma config WDTEN = OFF // Watchdog Timer (WDT disabled in hardware; SWDTEN bit disabled)
#pragma config WDTPS = 1 // Watchdog Postscaler (1:1)
// CONFIG3H
#pragma config CANMX = PORTC // ECAN Mux bit (ECAN TX and RX pins are located on RC6 and RC7, respectively)
#pragma config MSSPMSK = MSK5 // MSSP address masking (5 bit address masking mode)
#pragma config MCLRE = OFF // Master Clear Enable (MCLR Disabled, RE3 Enabled)
// CONFIG4L
#pragma config STVREN = OFF // Stack Overflow Reset (Disabled)
#pragma config BBSIZ = BB1K // Boot Block Size (1K word Boot Block size)
// CONFIG5L
#pragma config CP0 = ON // Code Protect 00800-01FFF (Enabled)
#pragma config CP1 = ON // Code Protect 02000-03FFF (Enabled)
#pragma config CP2 = ON // Code Protect 04000-05FFF (Enabled)
#pragma config CP3 = ON // Code Protect 06000-07FFF (Enabled)
// CONFIG5H
#pragma config CPB = ON // Code Protect Boot (Enabled)
#pragma config CPD = ON // Data EE Read Protect (Enabled)
// CONFIG6L
#pragma config WRT0 = ON // Table Write Protect 00800-01FFF (Enabled)
#pragma config WRT1 = ON // Table Write Protect 02000-03FFF (Enabled)
#pragma config WRT2 = ON // Table Write Protect 04000-05FFF (Enabled)
#pragma config WRT3 = ON // Table Write Protect 06000-07FFF (Enabled)
// CONFIG6H
#pragma config WRTC = ON // Config. Write Protect (Enabled)
#pragma config WRTB = ON // Table Write Protect Boot (Enabled)
#pragma config WRTD = ON // Data EE Write Protect (Enabled)
// CONFIG7L
#pragma config EBTR0 = ON // Table Read Protect 00800-01FFF (Enabled)
#pragma config EBTR1 = ON // Table Read Protect 02000-03FFF (Enabled)
#pragma config EBTR2 = ON // Table Read Protect 04000-05FFF (Enabled)
#pragma config EBTR3 = ON // Table Read Protect 06000-07FFF (Enabled)
// CONFIG7H
#pragma config EBTRB = ON // Table Read Protect Boot (Enabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
#define Buzzer LATDbits.LATD0
#define TRUE 1
#define Buzzer_HIGH 1
#define Buzzer_LOW 0
void Port_Initialized (void)
ANCON0 = 0; // Set to digital port
ANCON1 = 0; // Set to digital port
CM1CON = 0; // Comparator off
CM2CON = 0; // Comparator off
ADCON0 = 0; // A/D conversion Disabled
ADCON1 = 0; // A/D conversion Disabled
ADCON2 = 0; // A/D conversion Disabled
LATA = 0;
LATB = 0;
LATC = 0;
LATD = 0;
LATE = 0;
TRISA = 0b0000000; // all are output, Unused
TRISB = 0b0000000; // all are output, Unused
TRISC = 0b0000000; // all are output, Unused
TRISD = 0b0000000; //all are output, Unused
TRISE = 0b0000000; // All are output, Unused
void main(void)
unsigned int count = 0;
Port_Initialized(); // Initialize the PORT
while(TRUE) // run forever
////Frequency 1
for ( count = 0; count < 80; count++ )
Buzzer = Buzzer_HIGH;
__delay_ms (1);
Buzzer = Buzzer_LOW;
__delay_ms (1) ;
//Frequency 2
for ( count = 0; count < 1000; count++ )
__delay_ms (2);
__delay_ms (2) ;
