DickCappels
- Joined Aug 21, 2008
- 10,661
It looks fine.
Are you driving the gate with a Raspberry Pi?
yes this is my project to control the boost and the buck boost by the raspberrypi i did that for the first converter(BOOST) .It looks fine.
I am glad to see that you have your specifications in writing. You can try to model the inductance you are about to order (including the equivalent series resistance) to see how much performance is improved by the new inductor, before you order it.yes i get on the output -9V in Rmax=125ohm ,and if i change duty cycle i would get -12V but my problem that if i change the load(resistor) to Rmin=25ohm i get 5V or 6V (I HAVE A BIG DIFFERENCE) i just want a 3V difference
