Controllers and compensators
YoGMan
Joined Sep 20, 2017
76
If I can't get the required specifications using PID or Lead-Lag compensators, what other compensators or controllers that exists that I can use to meet the settling time, and steady state error requirements ?
RobNevada
Joined Jul 29, 2019
66
You might look at a PAC instead of an PLC. Depending on the PLC microprocessor from an input signal to an output there is a delay (sometimes 20 milliseconds). PAC controllers have about a 2 millsecond delay. If you describe more of your application. Like what sensor you are using using and how it is creating issues. That would be of help.
YoGMan
Joined Sep 20, 2017
76
I have the transfer function of my plant which is third order and i'm connecting it in unity negative feedback loop. I have specifications of settling time and % overshoot and steady steady state error to a ramp input to meet BUT I cant approximate the system as a second order to do calculations. How can I meet the required specs by showing manual calculations ?
YoGMan
Joined Sep 20, 2017
76
Hello everyone, thanks for your help, ive been able to design using state space and relocate the poles... ive calculated the gains for state feedback but everytime the output becomes unstable when I model the state space on simulink, whereas the results are okay when I use transfer function directly....1573848055056.png
MrAl
Joined Jun 17, 2014
11,486
Hello everyone, thanks for your help, ive been able to design using state space and relocate the poles... ive calculated the gains for state feedback but everytime the output becomes unstable when I model the state space on simulink, whereas the results are okay when I use transfer function directly....View attachment 191513
I was going to suggest state space, ie state variable feedback.
I dont think you can beat that if it is done right.
Beware the theory vs implementation where you could get unaccounted for clipping of signals.
What is this system supposed to do?
YoGMan
Joined Sep 20, 2017
76
Thank you I have been able to do it , I just had to design a controller to meet certain specifications on a sampled signal. Thanks again ;)
