controlled current source functionality question
yef smith
Joined Aug 2, 2020
1,485
Hello Alec, i have tried it, its not working.
could you please post LTSPICE file?
Also 100K resistors will create a lot of noise.
I need to see the logic behind the numbers.
yef smith
Joined Aug 2, 2020
1,485
Hello Alec,I want to learn how the resistor play together.
there is a very interesting mechanism of feedback which sets the mosfets states.
5K is a very noisy resistor so i need to understand the logic of the ratios between the resistors.
could you please give an intuitions regarding the roles of the resistors?
Thanks.
Alec_t
Joined Sep 17, 2013
15,163
It's not a circuit configuration I'm familiar with. It involves an unknown (to me) variation in the current through the opamp's supply pins as the input voltage changes.
