Controll drone by a laptop
smnksng
Joined May 3, 2021
Im currently building my own drone and I was wondering, if I could controll it with a laptop rather than an RC Transmitter, because I mainly want it to fly autonomously.
Could I f.ex. just buy an FrSky receiver and control it with a laptop?
And if I want to change the waypoints while the drone is in the air, do I use a telemetry module, an RC receiver or something different?
Thanks in advance
LowQCab
Joined Nov 6, 2012
5,102
Drones can be quite dangerous.
You need to get a proper RC-Transmitter so that you can run a
Flight Simulator Program on your Computer and get used to controlling a Drone
with a Transmitter similar to, or the actual Transmitter, that you intend to use.
You NEED to have instant access to the Transmitter-Controls to "Kill" the Drone if necessary.
100% Autonomous-Flight is a BAD IDEA.
You have to have a proper RC-Transmitter to deliver even basic instructions to the Flight-Controller.
RC-Transmitters are not controllable via Lap-Top.
In many Locations it is specifically against the Law to do what you are proposing.
If you screw-up it makes ALL RC-Enthusiasts look bad, and
causes MORE stupid Laws to be written.
You know just enough to be dangerous.
Buy a RTF (Ready-to-Fly) Model and put in at least a hundred hours of learning how to fly it.
When you can fly it in "Acro-Mode" with no Auto-Stabilization features engaged,
then build your own,
so that you will have to learn what makes every function work,
and exactly why it's done that way.
smnksng
Joined May 3, 2021
All right seems like buying a transmitter is a good idea. But how do I change waypoints during the flight or in general can access the data of my gps module like I can on my smartphone when I fly my dji mini 2? Because i reckon I cant just plug my phone into the transmitter
SamR
Joined Mar 19, 2019
5,542
I have seen flight controls with a phone mount used to "fly by point of camera eye view from drone" instead of remote ground viewing or my son uses a virtual reality goggle to do so. As to control apps, dunno, do some googling... You will need a multichannel RC controller that has the ability to interface. What he flies are the small (not micro) scratch built acrobatic drones with cameras and limited range/flight time. I've tried to get him interested in the larger long range camera platforms, but he is autistic and has a mind of his own about how to do things. His does display a battery monitor bar and signal strength.
