control design of doors,lights and gates interfacing with a pc
dachy12
Joined Oct 27, 2008
4
How to design and implement a system which will be used to control remotely the lights, gates and doors in a building by using the parallel ports of the pc for interfacing the hardware part and the pc which will be used as the controller
Wendy
Joined Mar 24, 2008
23,869
Ever hear of SSR's (Solid State Relay's)? They are optically coupled triacs which require very low voltage and current to control AC. You can use your printer port to control them. To test the interface safely you can even use conventional LED's w/ resistors, and replace them with the SSR later.
The printer port may not have enough control lines, you'll have to figure that one out yourself.
http://ourworld.compuserve.com/homepages/Bill_Bowden/page6.htm#PPRIC
BTW, the same printer port can also be used as an input.
SgtWookie had an excellent suggestion concerning this idea though, buy a printer interface card. If you slip and burn it out you don't have to replace a motherboard. They're also pretty cheap too, another bonus.
dachy12
Joined Oct 27, 2008
4
can you help me with the circuit for controlling lights,gates and doors in a building by using a pc as the controler
