Control 120VAC Autotransformer with PLC
HighVoltage!
Joined Apr 28, 2014
182
I am trying to control the rate of rise (example: 5VAC/minute) of the output voltage of Autotransformer. What is the best way I can do this? Do they sell units that I can "tap a PLC into"?
MrAl
Joined Jun 17, 2014
13,791
I would think an AC output converter that has adjustable output voltage would be a start, but they also make motor driven variacs you can use since you need a slow change in output voltage. I don't know the application though so that could be different.
HighVoltage!
Joined Apr 28, 2014
182
Do you know who sells affordable motor driven variacs?
HighVoltage!
Joined Apr 28, 2014
182
What exactly is the application?
What supply voltage?
The primary supply voltage is 120VAC. Is it then fed into a step-up transformer (kV output range) which its output (secondary) is rectified to DC. I would like to control the the primary supply voltage to have control of rectified kVDC.
HighVoltage!
Joined Apr 28, 2014
182
Part number for converter?
0-120VAC = variable output
4-20mA or 0-10VDC = voltage input
Reloadron
Joined Jan 15, 2015
7,940
You find an autotransformer that meets your demand. Names like STACO come to mind. Large autotransformers are normally driven by Slo-Syn motors.
Ron
28,240
It sounds like the TS is asking for a servomotor controller for an equivalent to a Powerstat or Variac device. I was confused by the reference to "autotransformer" even though it is indeed technically correct.
Motorized versions of those have been available for many years, but most are adjusted by a 72 RPM synchronous motor. Vor a variable rate that will need to be either a stepper motor or a servomotor. Both are available with appropriate controllers.
