Did you ever figure out that your circuit won't work? If you have an adder circuit after the counter, if the counter had a count of 5-9, the output from the adder would be an invalid code. As I mentioned in my previous post:so i can only add 0-9 and i want it to be 0-99. here's my new circuit schem.
Have you checked the behavior if the count is 6-9 and you try to add 5?
Personally, I don't think it's worth working on. The idea was seriously flawed.Looks like the TS just ignored your advice to check if the circuit works right.
I will work on the circuit as it didn't increment properly with the units (6-9) when +5 is pressed.
