ronsimpson
- Joined Oct 7, 2019
- 4,787
I would make a PCB with those two 100 pin connectors on board.ronsimpson said:
Are you testing for opens? broken wire --- Yes
Are you testing for shorts? - Yes
Are you testing for crossed wires? -- Yes
Is there a connector on the ends? -- Yes
I would make a 100 long shift register that drives one end of the cable.
Have 100 resistors to slightly pull down on the other end to -5V.
Start out and drive the cable with 100000000...... and look at the other end to see if that is what you get back.
Next advance the clock and output 01000000, then 00100000 and 0001000. I think we called that walking bit.
A good wire should read 0V or 5V when it should. A shorted wire will read back 2.5V or some other odd voltage.
A open wire will read -5V. Do that test first.
I don't have time right now to say, but by sending certain patterns down the wire you can do the test in 1/10 as many tests.
I have not built one of these in years.
