3 OHM CONTINUITY TESTER - MODIFICATION REQUIRED FOR 3 OHMS
dave321
Joined Dec 10, 2010
65
hi,
the attached circuit reliably tests 1ohm and below.
i want to test 3 ohms and below, what change in component values would i have to meke to achieve this please ?
(i think they would only be resistor value changes but i am not that clever with understanding how to calculate what is required.)
i basically want a "go / no go" quick tester for less than 3 ohms
thank you dave
dave321
Joined Dec 10, 2010
65
hi sghioto,
yes it is, BUT only the bare chip, no pyrogen, so no danger,
can you help ?
will the change of R5 to 6.8k ohm work ? i have not tried it yet
dave
sghioto
Joined Dec 31, 2017
8,756
I believe so as that value of 6.8K is appx 3 times the value of R5.
BTW the max current through the igniter is only 16ma, should be safe with the pyrogen.
That circuit schematic looks wrong to me. The transistor is merely switching on power to the op-amp, although there is constant leakage current from battery to the IC's (+) input. The buzzer does not connect to the LED but rather to the op-amp output pin 1.
Another variation on the web adds an LED to the input. It could use a decoupling capacitor on power.
Just mentioning it's a circuit with mistakes IMHO.
sghioto
Joined Dec 31, 2017
8,756
I don't see any of those issues.
Igniter is connected, the power switch is turned ON.
If the buzzer sounds and the LED lights up then the igniter resistance is above 3 ohms.
After all the TS mentioned it was reliable in post #1.
dave321
Joined Dec 10, 2010
65
it actually works better with R5 as 5k ohms, it will the light the LED at 3ohms and under, but will not light it at 3.3 ohms.
excellent, job done. (i decided not to use the buzzer).
dave321
Joined Dec 10, 2010
65
Looks suspiciously like this design, without the circuit protections.
The connection to the LED and buzzer looks strange? is that to clamp the buzzer voltage at ~3Volts?
In my design R11 sets the threshold of detection.
i have not seen that design and i am not an electronics guru like some of you guys.
that is why i occasionally ask for help.
