Constant coltage on latching relay
Foulkesey
Joined May 8, 2015
6
Hi guys,
I want to install a dual coil latching relay, only problem is the voltage to the coils will not be pulse they would be constant but i also require relay to latch once all power is off.
Is this possible?
Cheers joe
MikeML
5,444
The dual coil latching relays are not usually designed to have their coil powered continuously, and will likely overheat if you do so.
Foulkesey
Joined May 8, 2015
6
Ok thanks, have you any ideas what else i could do, i need to add a relay controlled by 2 seperate switches with constant voltage, yet needs to latch in position once all power is off? Cheers
38,525
If you explain exactly what you are trying to do, then perhaps we can suggest the best approach.
Why do you need it latched when power is removed?
