connection of charge controller, battery and inverter
aspirea5745
Joined Apr 17, 2019
106
I do not understand the connection of charge controller, battery and inverter in following picture. Solar panels generate DC electricity, charge controller protects the battery from overcharging. battery store DC power and inverter converts DC voltages into AC voltage.
KeithWalker
Joined Jul 10, 2017
3,618
I agree. The diagram is very vague and misleading. The charge controller should be shown connected directly between the solar panel and the battery, and the inverter directly between the battery and the house. Usually, in commercial systems, the charge controller and invertor are combined ito one integrated unit.
Keith
aspirea5745
Joined Apr 17, 2019
106
Keith
I have fixed it
Can you tell me What charge controller will be required for 1kw solar panel?
KeithWalker
Joined Jul 10, 2017
3,618
The charge controller must have an input that will match the voltage of the solar panels. The output must be able to supply enough current to run the load as well as charge the 3.6V battery pack. I can not be more specific than that because I don't know enough about the solar panel or load or how often and for how long the load will be connected. I also don't know at what lattitude you live or what the average sunshine is there.
Keith
