connecting to smps together
Dodgydave
Joined Jun 22, 2012
11,395
Yes as long as the Negative supplies are not connected to the mains Earth /ground case, usually there is a link connected between the case and the Negative output, remove it.
Your current will be limited to the supply with the lowest current limit.
