Connecting CJMCU-2232 FT2232HL
bibble235
Joined May 29, 2018
63
Hi
I am having trouble connecting a FT2322HL to my ESP32. I have followed instructions from the site which said
GPIO12 - AD1 (TDI)
GPIO15 - AD2 (TDO)
GPIO13 - AD0 (TCK)
GPIO14 - AD3 (TMS)
GND - GND
Using two USB leads on my PC and the device was detected.
Code:
Nov 28 11:37:04 OLIVER kernel: [866817.408763] usb 3-1: Product: Dual RS232-HS
Nov 28 11:37:04 OLIVER kernel: [866817.408765] usb 3-1: Manufacturer: FTDI
Nov 28 11:37:04 OLIVER kernel: [866817.409369] ftdi_sio 3-1:1.0: FTDI USB Serial Device converter detected
Nov 28 11:37:04 OLIVER kernel: [866817.409399] usb 3-1: Detected FT2232H
Nov 28 11:37:04 OLIVER kernel: [866817.409504] usb 3-1: FTDI USB Serial Device converter now attached to ttyUSB1
Nov 28 11:37:04 OLIVER kernel: [866817.409642] ftdi_sio 3-1:1.1: FTDI USB Serial Device converter detected
My problem is I believe I have blown up two of these. When plugging in the PC I get.
Code:
Nov 28 11:49:35 OLIVER kernel: [867568.310952] usb 3-1: device not accepting address 83, error -71
Nov 28 11:49:35 OLIVER kernel: [867568.311006] usb usb3-port1: unable to enumerate USB device
Nov 28 11:49:35 OLIVER kernel: [867568.570923] usb 3-1: new high-speed USB device number 84 using xhci_hcd
Nov 28 11:49:36 OLIVER kernel: [867568.698911] usb 3-1: device descriptor read/64, error -71
Nov 28 11:49:36 OLIVER kernel: [867568.934904] usb 3-1: device descriptor read/64, error -71 Nov 28 11:49:36 OLIVER kernel: [867569.170858] usb 3-1: new high-speed USB device number 85 us
With two board blown I would be keen to understand how people would normal do this. Or if I am doing something wrong and it is not the leads. I am new to this so do not know the best approach but happy to learn from people who do.
Question from again, a novice are
1/ Is there a better way to connect five wires more securely
2/ Is there a standard way to guard the live pins aside from insulation tape
3/ Can I still connect without the usb via another usb board I have.
4/ What is the best site to buy parts from as I am in NZ
This is an image of the devices
An this is the site I used
Site Used
bibble235
Joined May 29, 2018
63
Yes seen this. And I did not connect either the 3V3 or the VCC (Not sure what VCC is but it sounded like power). I powered mine using the USB cable. for Me I connected as above A0-A3 only
Wolframore
Joined Jan 21, 2019
2,610
A few suggestions while waiting for verification
1. plug the ESP32 board into the breadboard, by doing this you will eliminate one set of jumpers reducing wire length and possible connection issue.
2. read through the instructions about replacing the driver for FTDI
3. verify that you have working devices isolate problem ones and identify what the problem is, if any
looks like you have what you need, just need to work out the issue, whether hardware or software.
