Hi
I want to connect a flow sensor (SF800) to a ESP12, since the ESP is running on 3.3v and the sensor needs 5V I need a logic level converter. I'm using one that uses pull up's and a mosfet (LLC.png).
On its HV (5V) end it has a 10k pull up resistor. According to the specs of my sensor it needs a 2200 pull up resistor (SF800-data.png).
The combined circuit would have a 10k and a 2200 resistors in parallel (R2 & R3 ESP-Flow-Dia.png), which I assume would not work.
Any suggestion on how the sensor can be connected, preferable using the same LLC?
