Hi, I am doing a Robotic hand Arduino Project using LabView. Aim is to control 5 servos using 5 flex sensors.when I tested each sensor separately it works fine, but when they are connected together outputs of each sensor varies when any one of the flex sensor is flexed (bent) and this is a problem be cause i need independent outputs.I have attached images of connection I did.
Please help me.
Thank You.
Please help me.
Thank You.
