Connect a proximity sensor with L7805cv
Taratata
Joined Feb 2, 2018
11
Soory for english language (is not my natural language)!
I did a small test without then capacitor with a NPN NO model PL-05N sensor on a L7805CV voltage regulator.
After some research the lab works. I have 5v during the contact.
The next day, I disconnect all to redo the lab to the identical, and nothing else works.
I checked the cables, changed the test board, tested L7805cv by measuring the 12v input then 5v output. here are some info for those who will have a track
here is my video -->
Lyonspride
Joined Jan 6, 2014
137
Am I right in saying your using the 7805 to drop the output voltage to 5v? Because that's not really how you use a linear regulator......
Lyonspride
Joined Jan 6, 2014
137
If your using it to drop the output to 5v and there is no other way (ie reducing sensor voltage), then what you need to do is have the 7805 permanently connected to supply voltage and switch the 5v from that (using a relay for example).
Remember the 7805 is 1A maximum or 1.5A for the CV (WITH heatsink), so be careful what you drive with that as well.
Looking at:
https://www.pcboard.ca/pl-05n-npn-proximity-sensor
150mA will drive a relay, but not suitable for directly driving a device of some kind, you may have blown your sensor :(
Lyonspride
Joined Jan 6, 2014
137
I can't do a schematic right now and i'm not very good at describing this in a way that the language barrier will allow your to understand.
dendad
Joined Feb 20, 2016
4,637
What is the 5V feeding?
Is it just the Prox out going into an input on a 3D printer?
And yes, your "branching scheme is wrong". You probably want to say your circuit diagram is wrong. But I am ignorant and can only speak one language myself. You are doing quite well!
Are you trying to switch a probe input on an Arduino 3D printer controller?
It does help if you put full details of your circuit here for us to read.
You can connect the PROX output to an optocoupler, like a PC817...
http://www.farnell.com/datasheets/73758.pdf
If the printer has pullups on the inputs, connect PC817 pin4 to the printer input and pin 3 to the printer com. This will pull the input down when the prox operates.
If the printer input has a pull down, connect PC817 pin 4 to +5V and pin 3 to the input. That will pull the input up to 5V when the prox operates.
Taratata
Joined Feb 2, 2018
11
I want to power the 12v proximity sensor by an ATX. Currently, my proximity sensor (LJC18A3-H-Z _BX) is on a voltage divider (5v output), all from ATX (it works very well). As I saw that there is the possibility to pass on L7805CV, I found interesting.
dendad
Joined Feb 20, 2016
4,637
Yes, but what is the prox output feeding into? What is reading the prox? That is the question.
The way you are using the 7805 is not the way to go and if we know what you are trying to do we can help.
Here is another picture showing the prox connection.
Is this what you are trying to do?
Taratata
Joined Feb 2, 2018
11
the proximity sensor is used for the survey (topography) of the heated bed and Z-home (prob)
is my first texst Here it work with a voltage divider bridge
dendad
Joined Feb 20, 2016
4,637
How were the original limit switches wired up? Was one side com or +5V? that is important.
What is your controller board?
And do not hook your Prox/7805 setup onto your printer as I think it may damage it.
I should be asleep now so will have to continue tomorrow.
Good night.
Taratata
Joined Feb 2, 2018
11
I use ramps1.4. the wriring on the prox is the blue cable sensor on pin Z_min - and the signal cable on pin Z_min S
Thank you for your help!
dendad
Joined Feb 20, 2016
4,637
I could not get to sleep.
You could try adding a 1N4148 diode between the Z_min S pin and the signal cable, with the stripe on the diode (cathode) towards the signal cable. That will stop the 12V from the sensor getting to the Ramps board and may still pull down enough to work the limit signal. The opto isolator is a better option as it fully protects the board from external voltages.
Taratata
Joined Feb 2, 2018
11
can i follow your schema? with 1N418?
