Confusing resistor colours
victorcjkuo
Joined Jun 28, 2021
Its been a while since i've had to work with PCB components and currently trying to fix a control board for my washing machine. I've identified that this resistor has blown but cant figure our the colouring on the 3rd band (see attached). It looks like gold but its a different colour to the tolerance band which is definitely gold. My guesses are 1ohm (seems really small) or 200ohm with the first brand actually being red (though really looks like brown to me)
Mod:Lightened your image.
DickCappels
Joined Aug 21, 2008
10,662
Looks pretty bad. Looks like that stripe got cooked. If you try to measure it, what do you see?
The color might become more distinct under sunlight.
victorcjkuo
Joined Jun 28, 2021
Thanks for both of your inputs! I took Delta Prime's suggestion and removed the resistor to take a proper look under better lighting and discovered that the stripe got completely cooked as DiockCappels suggested. Colour was completely burnt off but fortunately still clear on the underside. Looks like its 100ohm!
thanks!
Dodgydave
Joined Jun 22, 2012
11,395
What is the washing machine model number, maybe you can search for the board and get a picture of it ?..
If Gold is the third colour then it's probably 10ohms..
