Than Wbahn.For experiment, I have taken out from the video cassette re-winder which we used many years back. I forgot to mentioned that I have used digital multimeter to measure the value of resistors rather than color codes.
I did not understand what DMM mean. DMM to directly measure the resistance of the motor's winding.Does this statement mean to measure the resistance of coil of motor without applying power? With understanding, I have measured resistance by touching one terminal of motor with red probe of meter and other terminal of mortar with black probe of meetr. Then the reading is 8.5 ohms.
NB: if i have done the correct way then. At 6.5mA, that the winding is roughly 15Ω. (as discussed ealier; when 1 volt is taken by motor winding. ie. R=v/I=1/6.5=15 Ohms
Your valuable suggestion or comments is anticipated.
