Confused over symbology used in Grobb's Basic Electronics
SamR
Joined Mar 19, 2019
5,542
In Chapter 18 it throws into the mix v(sub)A in discussing capacitive voltage v(sub)c and capacitive current i(sub)c. V(sub)A is applied voltage from the power source but what is v(sub)A?
EDIT: or is it an errata?
SamR
Joined Mar 19, 2019
5,542
OK I think I found the answer. Lower case v or i indicates the instantaneous value of a variable as V voltage and I current are in AC voltage.
WBahn
Joined Mar 31, 2012
33,321
A common convention is that upper case variables are used for DC values while lower case variables are used to time-varying values. Without seeing a screenshot of the actual use, what my mind brings to mind is that the power source is applying a time-varying signal in which case it would be v_A(t) and the V_A wouldn't be used at all (unless it is representing a phasor). But the specific context might make it meaningful to use both.
SamR
Joined Mar 19, 2019
5,542
Yes it is right along with phasors and discussing v lagging i by 90 degrees and displaying both sinusoidal and phasor descriptions. I found it all the way back in the first chapter in a footnote to a chart. It was the sudden use as a time variable for AC that threw me. Got it now. Thx
