An alternator diode problem.
My track loader is not charging the battery.
Simple rectifier bridge, diode, is mounted in the fuse panel. I’m trying to test. With a cheap $20 multi meter. Rather than measuring voltage drop it measures resistance in Kohms when set to the diode test.
Reads 468. Manual says 1.5 mA is the impressed voltage used.
Should I simply multiply 468 by 1.5 mA To get the voltage drop? Confused by the manual which states that readout is in
K ohms Not ohms! If so that gives 700 V. Does not make sense. Your insight is appreciated.
From what I understand a good fluke meter would simply read out the actual voltage.
