comparator with internal hysteresis
electronicsenjoyer089
Joined Feb 24, 2025
182
Hello all, im trying to build some kind of frequency-voltage converter, i started out with the first block which is a comparator with internal hysteresis, so it doesnt need external resistors, and vref is vcc/2.
I did the simulation after importing the component, but in output i dont see a square wave with 50% duty cycle, why so? the circuit connections should be simple,i dont explain my self why i dont see any, consider that output is push-pull.
Thanks all
BobTPH
Joined Jun 5, 2013
11,654
It sure looks like that should produce a square wave output. Are you certain of the device model, because that is the only thing I see that might be wrong.
Joined Feb 24, 2025
182
Yeah its the correct one, i copied the parameters in the directive and created a symbol with .SUBCKT TLV7031 IN+ IN- V+ V- OUT , right clicking on this.
eetech00
Joined Jun 8, 2013
4,724
Thanks all
Remove the .subckt statement from your schematic.
Change the .trans duration to something reasonable so you can see the 3khz waveform.
Per=1/3k=333.3 usec (one cycle) x 10 cycles= 3.33 msec
Maybe like this:
.tran 0 5m
