Common emitter amplifier help
Garydwall
Joined May 16, 2019
22
15792958673917125838289326842984.jpgHello folks. I'm new to electronics so sorry if this is a really stupid question.
Can someone please confirm what the function of the resistor on the collector and resistor on the emitter are for. I have a test tomorrow and I think it's coming up. In the picture it's r 3 and r4
Thanks very much
MrAl
Joined Jun 17, 2014
13,859
The emitter resistor is there to improve linearity and thus total harmonic distortion. There is also a bias improvement. It also helps to stabilize the circuit gain because it provides some negative feedback.
Can you figure out why any or all of these things improve after doing an analysis or at least using a simulator? If you want to understand this you should look into it.
