Combination Shift Register/Latch?
johnyradio
Joined Oct 26, 2012
615
Just wondering if there's a Combination Shift Register/Latch on a chip.
If not, is there a programmable logic chip, that could do shift reg, latch, and demux?
Budget, 20 cents
dl324
Joined Mar 30, 2015
18,524
Budget, 20 cents
Yes, but you're probably not going to get them for 20 cents unless you buy thousands.
johnyradio
Joined Oct 26, 2012
615
Why were you asking if you already knew? Took all of 30 seconds to search Digikey (but I knew a part number to search for): Shift Registers | Logic | Electronic Components Distributor DigiKey
I didn't already know. I was referred to that chip after i posted this thread. So I was going to delete this thread, but then i saw your reply.
I did search Digi, but i didn't know what the device is called, so i didn't know what to look for .
Someone might post other nice chips here.
Cheers!
