Colpitts oscillator parameters
MrAl
Joined Jun 17, 2014
13,785
I was just experimenting by replacing capacitors and inductors and the frequency continue being the same.
Well one of the reasons i asked was because if you change a 100uH inductor with another 100uH inductor you wont see any change.
Also, if you change them such that the capacitors and the inductor results in the same frequency, you also wont see a change.
That's why it is important to know what components you are changing, and from what values to what other values, and hopefully your measurements too.
Ylli
Joined Nov 13, 2015
1,092
How did you assemble this mechanically? It's possible you have an unintended feedback path that is bypassing the intended components.
Antsy electron
Joined Dec 27, 2022
69
I replaced different capacitors values.
