Hi guys,
I'm working on a metal detector project and I need some external input/ideas on how to increase its range.
Here's how it works:
Its a basic Colpitts oscillator featuring a self wound Inducting coil. This coil is on a diameter 125mm former with 0.25mm enameled copper wire consisting of 26 turns. The circuit works fine and produces an oscillating frequency of approximately 160 kHz.
When a metallic object is brought close to the coil, the varying magnetic field induces Eddy currents in it which lower the inductance of the coil hence increasing the frequency of the oscillator. The closer the object the greater this frequency deviation. At the moment the frequency deviation begins to get slightly noticeable when the object is approximately 10cm away. Problem is, I need this coil to be able to detect objects at approximately 20cm away or greater if possible.
My thoughts are:
Either try to increase the current through the coil
or increase the number of turns on the coil.
I can perhaps increase the coil diameter up to 200mm, and I don't mind having oscillating frequency reduced as much as to 120kHz (which may come from increasing turns).
Any input will be much appreciated!
My thoughts are:
