colpitts oscilator in multisim
aragon1971
Joined Apr 7, 2008
160
Hi
i run a colpitts oscilator in multisim but the circuit not working
on the contrary the circuit in the Breadboard working what happen ?
28,584
Simulators are often not able to start an oscillator circuit. So you might get the oscillator running by inserting a single pulse. I think that BOB PEASE commented on that once.
aragon1971
Joined Apr 7, 2008
160
thank ! if i change the value of coils L= from 10μF to 10mF and Rfcoil from 200μH to 300mH the circuit working !!
28,584
OK, I see that it is oscillating very well. It looks like the signal is 20 volts peak to peak, and not distorted.
Some sets of component values do not work. And some others work very well.
Bordodynov
Joined May 20, 2015
3,433
I have repeatedly watched Multisim users make a big mistake. You have made it, too. It is not taking into account the series resistance of the inductance. Are your windings made of superconductor?
Substitute reasonable values for series resistances.
aragon1971
Joined Apr 7, 2008
160
thank for the answer ! you mean the resistanece of real coil ? because the coil from the multi sim library is ideal
Bordodynov
Joined May 20, 2015
3,433
LTspice.
I wasn't hiding anything. If you look carefully, in the upper left corner of the picture you will see the name of the program.
In Multisim there are two models of the 2N2222A transistor. The first model is not the correct one. The second model is correct.
LTspice has a much wider list of factory models (with parasitic parameters) of inductors and capacitors compared to Multisim.
Also more convenient to search by volume, manufacturer, type and voltage or current.2023-03-24_07-57-38.png
aragon1971
Joined Apr 7, 2008
160
LTspice.
Also more convenient to search by volume, manufacturer, type and voltage or current.View attachment 290568
With the previous values of L=10μΗ and L=200μF ( for RF coil choke) in LTspice the oscilator working ?
28,584
One thing about oscillators is that not all of them start quickly, and not all of them produce a clean sine wave. And not all of them are equally stable. In addition, some combinations of L and C in the tuned circuit will be excessively sensitive to outside influences.
The circuit in post #7 seems to build amplitude rather slowly, as an example.
Bordodynov
Joined May 20, 2015
3,433
It is more practical to use the following values: L=10μΗ Lrf=200μH. In general, this is a strange question. Do you need to have generation and don't care about frequency? Are you going to make a layout or do you only need calculation in Multisim?
aragon1971
Joined Apr 7, 2008
160
the only difference is the frequnecy of oscillation in fisrt case the f0=357kHz and the second case f0=11.3 kHz and the impedance of rf coil is XRF=449 Ω and XRF=13 Ω . i aks according to theory what is the most consistent' value?
