Collector emmiter open circuit voltage
ham3388
Joined Jul 3, 2012
97
Could you please calculate the Vce maximum , or show me how to calculate it ,I really don't know how to find it.
38,764
The worst-case collector voltage is when the AC signal peak is high enough to completely turn off the transistor.
Assume the emitter voltage doesn't change significantly from this due to the capacitor bypass across the emitter resistor.
I'll let you determine what the Vce is at that point.
ham3388
Joined Jul 3, 2012
97
Vc = 20.23 mA × 100 = 2.023 v
This is what I understand
Vcc = Vc + Vce + Ve
24 = (20.23 mA × 560 ) + ( 10.64 ) + ( 20.23 mA x 100 )
The transistor resistance = 10.64 ÷ 20.23=526 ohm
When on peak
Vcc peak = 24 × 1.41 = 33.94 V
If the emitter voltage does not change then
This voltage should affect the current flowing into the Rc and the transistor and greater current should flow in.
Or maybe the current through the Rc remain the same but we shall experience a higher voltage across the transistor then higher current will flow into the transistor which may damage it.
33.94 - 24 = 9.94 v
This is the extra voltage due to the peak voltage
We shall add this to the Vce
9.94 + 10.6 = 20.54 v
I don't know how far this is correct.
ham3388
Joined Jul 3, 2012
97
Yes ..you are right
It is a dc voltage.
I really mixed up.....
Could you guys give a clear method which enables me to find the Vceo?
ham3388
Joined Jul 3, 2012
97
Current flowing in the emitter and collector when the base is open is
I = 24 ÷( 100 + 560 ) = 36 mA
Vc = 36 × 560 = 20.36 v
So what should I do forther?
38,764
You really need to think about what is happening in the circuit, otherwise how are how are you going to solve other similar problems?
You can't have someone else solve them all for you.
You've determined the DC bias voltage across the collector and emitter.
When you apply an AC signal at the input it generates an amplified AC signal at the collector.
The maximum peak AC voltage you can have is when the transistor shuts off and the collector ries to the supply voltage.
The AC voltage doesn't appear at the emitter due to the capacitor bypass so the emitter voltage doesn't change from the bias value.
So then what is the maximum voltage across the transistor?
cjcgmjs
Joined Oct 2, 2016
5
Hi Jony,
I saw your post somewhere else. I'm trying to import 4538 one-shot model to LTspice. I downloaded the "extra"
zip-file you uploaded, but it failed to work. Can you help with this? My email is jxm841@case.edu.
cjcgmjs
Joined Oct 2, 2016
5
Hi Jony130,
Thanks for your reply. I'm having trouble simulating it. I put the CD4538.asy in the C:\Users\J**** M***\Documents\LTspiceXVII\lib\sym, and the CD4000.lib file under dir lib/sub, but the system shows "unknown subcircuit" called in when simulating. Can you show me more how you make it work in more details?
Thanks very much
