Hi all,
First post here. I'm experimenting with a project that detects a coin going into a hat. I started by buying a cheap hand-held metal detector on ebay which gave some promising results but the diameter was too small. I removed the copper wound coil and re-wound it to fit the diameter of a hat brim. This little hack is working with big coins but isn't sensitive enough for small ones.
I'm looking for advice on how to increase the sensitivity of something like this. Eg - would it work to use more winds with a longer wire? change wire thickness? Or will I need a more powerful unit to achieve what I need, or possibly a different approach altogether? Any ideas much appreciated. I don't have a great knowledge of the theory behind all this but have decent soldering skills and basic electronic experience with arduino, pressure sensors etc.
Cheers.
Cheers.
