CO2 sensor for low volumes
Runzolf
Joined May 10, 2022
I'm a student in medical engineering, looking for a new CO2 sensor for a veterinary support setup. What I'm looking for is to monitor the CO2 level in mice and rats exhalation. We are talking about ~4ml of tidal volume (volume per breath), which is a crucial factor. The update rate should be at least 4sec / 0.25Hz, while the range I'm looking for is max 100'000ppm / 10%. Even 5% could actually be fine.
Right now I have two K33 30% CO2 sensors, which seems perfect, but unluckily they stopped working so I'm looking for an alternative.
Also, the sensor must offer I2C / UART connection, in order to interface it with a microcontroller.
Any advice is really appreciated!
Rodolfo
35,022
Welcome to AAC!
Why such a high range, 10%?
The typical range I have encountered is below 1%. I have not examined all the latest sensors available.
Would something like this work for you?
Runzolf
Joined May 10, 2022
Welcome to AAC!
Thanks so much for your quick response! I'm interested in evaluating rats / mices breath, the exhalation tends to have 4/5% CO2 concentration. The sensor you showed me is around 10000ppm / 1% so not actually suitable.
I found the Senseair K30, which could be good enough, do you still know of any alternative? K30 seems unavailable in my area...
