- Joined Jan 23, 2018
- 28,305
For details on "supervised wiring" I suggest a study of fire detection and alarming systems. The schemes for verifying the integrity of wiring and switches are quite mature, because fire protection systems are life critical.That is correct. The concern is more about assuring all wiring and switches are operating as expected. Also, want to try to isolate where a fault would be located in case of a problem. Thanks to all for the input.
Certainly this is a lot more complicated than LEDs displaying the operation of a switch, but, as I have explained to some clients,
"it is quite challenging to sense the difference between Zero and Nothing." That is where the supervising portion comes into the picture.
Indicators on a PLC input module will show if a switch has opened or closed, but they will not tell you if the switch will be able to signal that it is open or closed. THAT is where "supervised" arrangements come into play. The good news is that all of that has already been researched and developed for fire safety/alarm industry.
